Using fuel temp sensor to trigger a fan on a fuel cooler
As title really, getting a bit of heat soak into the fuel system, is it possible (are the channels etc there) on an s6pnp to trigger a fuel cooler fan at a preset fuel temp?
Re: Using fuel temp sensor to trigger a fan on a fuel cooler
Had a quick look, and I can't see any way to do this on an S6, although it would be easy on an S8
While maybe awkward.
use the brake light output and configure the temp sensor to the relevant input ?
The numbers wont make sense, but it should function.
Or likewise Nitrous bottle heater function via Nitrous pressure input.
Excellent lateral thinking there - like it
