S6 running with SR20DET
For Nissan Technical Chat
Sponsored by www.h-dev.co.uk
Jez
Horsham Developments
Post by Jez »
Just got to sort out the cold start, figure out why I'm not getting a speed reading from my ABS sensors and get some pins from somewhere so I can get my boost control solenoid wired up.
Re: S6 running with SR20DET
Good stuff Jez
Is this in your TA car?
Jez
Post by Jez »
Yup - should be good :)
Got the cold start and closed loop lambda control sorted this evening
How did mapping go Jez?
Jez
Post by Jez »
Not too bad. Some how managed 530bhp at 1.4 bar (got 470bhp on the old ECU, reckon its down to the rings being bedded in after the last track day - the engine has only done around 350 miles) and 549 at 1.6bar. I'm quite det limited, which I think it due to the CR being higher than I'd have liked. But still, 550bhp in a 1100kg car is good fun :)
Wez
Santa's Little Helper
Post by Wez »
Jez wrote:Not too bad. Some how managed 530bhp at 1.4 bar (got 470bhp on the old ECU, reckon its down to the rings being bedded in after the last track day - the engine has only done around 350 miles) and 549 at 1.6bar. I'm quite det limited, which I think it due to the CR being higher than I'd have liked. But still, 550bhp in a 1100kg car is good fun :)
You had chance to try it in anger or you waiting for abingdon?
Jez
Post by Jez »
Not tried it properly on the road or track yet. I have been for a quick blast though and its chuffing quick.
