Toyota 1ZZ trigger on S6? Ryan perhaps?
jezzpalmer
Post by jezzpalmer »
Howdo,
I'm trying to configure my S6 for a 1ZZ trigger and sensor, but strugging to get 360 sync (running on test bench with no cam sensor).
The trigger is not conventional, in that the gap isn't a gap but a tooth so i'm not sure if that's where I'm failing, it's also a big tooth, which AFAICT makes the disc 36-3.
I have...
Single Gap Single Cam
Number of crank teeth = 33
Number of crank tooth gap definitions = 33
Crank tooth gap widths = all 10deg apart from the second, which is 40deg
Minimum widths = 5deg all bar second which is 20deg
Maximum widths = 15deg all bar the second which is 60deg.
Here's a picture of the trigger...
Has anyone set one of these up? Or can anyone see where I'm going wrong?
Many thanks,
Jezz.
jezzpalmer
Re: Toyota 1ZZ trigger on S6? Ryan perhaps?
Doh, seems it's a 36-2 and is now working. :oops:
Good stuff Jez
Nice when you fix it on your own. Good work!
