Latest Firmware Releases
The Syvecs 2.4 Inch TinyDash is a compact competitively priced display designed as an easy to install and convenient source of vital information from your powertrain control system.
This thread is for tracking the firmware builds of the Syvecs TinyDash. When a new release is available it will be added to the end of this thread.
Updating the TinyDash is done via a USB C cable on the back and using our Syvecs Updater Program -https://www.syvecs.com/downloads/Syvecs_Updater.pdf
Initial Release: 1.4.2
www.syvecs.com/downloads/TinyDash_1-4-2.enc
1.4.3 Firmware
Relase 1.4.3
BugFix - EGT Scaling
BugFix - FuelComp Scaling
www.syvecs.com/downloads/TinyDash_1-4-3.enc
1.5.1 Firmware
Relase 1.5.1
Added LimpMode support
LimpMode Item uses the following Decimal values for each Limp:
"OFF" , 0)
"LIMP SWITCH ON" , 1)
"ECT COLD" , 2)
"EOT COLD" , 3)
"SENSOR WARNING LEVEL" , 4)
"AUTO TRANS" , 5)
"VEHICLE SPEED FAULT" , 6)
"EOP TRIP" , 100)
"CCP TRIP" , 101)
"KNOCK SHUTDOWN" , 102)
"EOT TRIP" , 103)
"ECT TRIP" , 104)
"FP TRIP" , 105)
"PREIGN SHUTDOWN" , 106)
"TIME ON LOAD LIMIT" , 107)
"TRQ TRIP" , 108)
"VVT FAIL" , 109)
"VBAT TRIP" , 110)
"LEAN TRIP" , 111)
"ACT TRIP" , 112)
"ECP TRIP" , 113)
www.syvecs.com/downloads/TinyDash_1-5-1.enc
1.7 Firmware
Release 1.7.1
- Added Change Light / ShiftLight Screen - Can Select a desired colour and active time based on an RPM
- Enable point map for Changelight or via ChangeLight with S7Fixed Stream
- Improved OBD2 Logic to work with all vehicles that support. If not supported it will now warn calibration in Scal.
- Added Oil Pressure Switch Output, Useful if your OEM Car does not have a Oil Pressure Sensor but a Switch. Can replace the Switch with a pressure sensor wired to a Input on the TinyDash, then use a TinyDash output to pull the OEM Oil Light switch to ground
- Added Unit Selection - Change Between Bar, Psi, C, F etc for different groups of sensors
- BugFix FuelMltCll
- Dip (Direct Injection Pressure) Added
- fuelDutySec Added
- Added Knock WarnLight - Looks at KnockWarn Item which is picked up from S7 Fixed Stream or can setup in Generic Receive
- Added Fan1,2,4,5 Items and Fan3,6,7,8Duty Items
- Added Fuel Pump Items
- BugFix Generic RX allows more than 16 ID's
https://www.syvecs.com/downloads/TinyDash_1-7-5.enc
1.15 Firmware
Release 1.15.1 ---- https://www.syvecs.com/downloads/TinyDash_1-15-1.enc
1.8 - CalSelect in CustomPWM Axis
- FuelComp BugFix for Generic RX
- OilTemp OBD2 Pickup
1.9 - Added Lam2Can Items and Canam CAN
1.10 - Added Ford Mustang / F150 CAN
1.11 - Added Max RPM Gauge Range option
1.12 - Added Option for Cal Overide is ALarm Active - Useful to drop Boost target or Custom map option
1.13 - Extended CAN Frame RX Fix and Added Fuel Tech CAN
1.14 - Added ecuCalSelect, Lambda Unit Selection Option
1.15 - Added Second Wastegate control option and Manifold pressure 2 option
Re: Latest Firmware Releases
Release 1.17.1 ---- https://www.syvecs.com/downloads/TinyDash_1-17-2.enc
1.16 - Added S8 and S12 Default Stream pickup option - See Layout for these in TinyDash Manual at bottom - http://www.syvecs.com/downloads/TinyDash_Manual.pdf
1.17 - Added MapG (Manifold Pressure Gauge) item to make boost easier to understand for end users
1.17.2 - Fixed issue with LinkEcu CAN
Release 1.18.2 ---- https://www.syvecs.com/downloads/TinyDash_1-18-2.enc
1.18 - Added GBT, Added AWDDuty, Added AWDTemp
1.18 - Added Hibernation/Sleep Option for OBD2 with constant 12v used, See
The TinyDash can go into hibernation with a constant 12v supply with OBD2 communication set in the pin assignments. If this feature is enabled and the OEM ECU stops replying to OBD2 requests then the TinyDash will go into Hibernation and wake again when OBD2 traffic is present... If the USB is connected it will stay awake
1.18 - Made Vbat Low Alarm gates on RPM
Release 1.20.2 ---- https://www.syvecs.com/downloads/TinyDash_1-20-3.enc
1.19 - Added Direct Injection Pressure and IGN Timing, OBD2 Updates to pickup Ignition Timing, Fuel Pressure and Intake Manifold Pressure 2 signal from OBD2
1.20 - Fixed wgMap1DT and wgMap2DT Scale, updated breakpoints for DT Table, Added filtering to wgMap1Dt and wgMap2Dt
1.20.2 - Change Layout 3 and 5 so that Item Text colour follow Text Colour in Scal not Box colour
Must use the Latest Ssuite Software found here - viewtopic.php?t=122
Release 1.20.4 - Added EcuCalSelect to Generic RX CAN
Release 1.21 - Added USB Datalogging
Release 1.21 ---- https://www.syvecs.com/downloads/TinyDash_1-21-2.enc
1.24 Firmware
- Added Fuel Level Input
- Flex Can Transmit Change to update byte swap more logically with endian swap
- Multiplexed CAN RX and TX Messages
- Triggered CAN Transmit, CAN Messages which are sent when an Item is greater then 0... Very useful with TinyDash V2 as can make Keypad buttons on Layout 8 transmit CAN messages like for DTC clear or to a PDU
- CustomPWM1 Double item issue
See help video on new CAN Changes here - https://youtu.be/8Yn1JitpXN0
Release 1.24.2 ---- https://www.syvecs.com/downloads/TinyDash_1-24-2.enc
Locked
