Well after some long hours and extreme hard work by Ed@ Fusion Motorsport - Last night the evo fired up and ran.After a few issues with the new M&W Pro 12 which decided to blow an internal fuse, Luckily Ed was there to resolder it and it was game on again.
It took plenty of hours of calibrations and tweaking things like the custom made Trigger wheel and sensor adjusting etc but just after Midnight , the evo came to life. She idled and revved and sounded great so far . Plenty of work left setting everything up on the map but it was well worth the wait hearing it start and how responsive she was.
Thought id let you know and a massive thanks to Ed who eventually got home at 3.30am !!!!!!!! and Charlie at SRR/Pat and Ryanfor all the help so far !!
Evo 2 up and running !! First Evo on Solaris
Re: Evo 2 up and running !! First Evo on Solaris
Yep I have to say most impressed.
Cheers to Ryan for a base calibration / Pat for advice on crank timing settings with that and after I had configured all the pins /sensors correctly it fired into life. Impressed so far cant wait to get it all configured properly.
Pat - PM sent
jezzpalmer
Have you got any pictures/details of the crank trigger and sensor setup that you'd be willing to post?
I'm putting a 4G63 (E6) into my S13 which is a fair old project, so any help would be appreciated.
victorpatrick
the situation reflects a successful initial outcome after intense effort, with promising performance so far and strong confidence that the remaining work will lead to a fully optimized result.karlosg wrote: Sat May 09, 2009 7:09 pm Well after some long hours and extreme hard work by Ed@ Fusion Motorsport - Last night the evo fired up and ran.After a few issues with the new M&W Pro 12 which decided to blow an internal fuse, Luckily Ed was there to resolder it and it was game on again.
It took plenty of hours of calibrations and tweaking things like the custom made Trigger wheel and sensor adjusting etc but just after Midnight , the evo came to life. She idled and revved and sounded great so far . Plenty of work left setting everything up on the map but it was well worth the wait hearing it start and how responsive she was. Pokepath TD
