Latest Firmware Releases
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
This thread is for tracking the firmware builds of the AWD Audi MQB units. When a new release is available it will be added to the end of this thread.
1.14.2
This is the first public release level
Firmware Version 1.14.2 - www.syvecs.com/downloads/AWD_Audi.enc
1.15
Version 1.15 contains the following updates
*Change Light Output Pin (HBR4)
*Drive ratio calculation for Gear detection on Manual Trans cars
*Enable Gear Detection from Drive Ratio option
*Change Light Min Speed
*Change Light RPM
*Change Light Min Tps
Firmware Version 1.15.2 - www.syvecs.com/downloads/AWD_AudiMQB.enc
1.18 Firmware
Changes since 1.15
1.18 - Added simple Map locking and Restriction option. - Press C, F inside a map
Firmware Version 1.18 - www.syvecs.com/downloads/AWD_AudiMQB_1-18-1.enc
1.21 Firmware
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_AudiMQB_1-21-1.enc
1.21.3
Version 1.21.3 contains the following updates
Changes since 1.21.1
* Handbrake is based on position NOT Switch. So can be used for holding Burnout
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_AudiMQB_1-21-3.enc
1.23 Firmware - X4
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_AudiMQB_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-23-1.enc
V1.23.3
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_AudiMQB_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-23-3.enc
1.24
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_AudiMQB_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-24-4.enc
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_AudiMQB_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-25-1.enc
Locked
