Guys,
Got Turbosmart Ewastegate and have a thought to drive it via X10. Wastegate requires 20amps (I guess that is max) and wonder if X10 is capable of providing that from half bridge 3 and 4? Driving DBW from half bridges 1 and 2 currently and these should provide 20 amps max according to LR manual. But what about 3 & 4 then?
Full H-bridge
Re: Full H-bridge
H Bridge 3 and 4 are same circuit BUT none of the H Bridges can handle 20Amp constantly! Only a peak
I would say not to use more than 25 and 75% on the duties and avoid using I term in the control so you don't wind up and have high duty for a long time!
Re: Full H-bridge
I'd also probably wire it with an inline fuse, you could always remove it once you're happy if you didn't want to keep it there.
Re: Full H-bridge
Thank you sirs. Running quite low back pressure (Garret GTX 4202R with Tial 1.30 housing) in 2.0 litre engine that would probably make life easier amperage wise. According to Turbosmart 20 amps should be max in very high back pressure applications. I see max 2-2.3 bar emap with 3-3.3 bar boost.
Re: Full H-bridge
It's a good point...and for any "power" ecu outputs too...MReilly wrote: Fri Dec 04, 2020 12:33 pm I'd also probably wire it with an inline fuse, you could always remove it once you're happy if you didn't want to keep it there.
Do they even have any overcurrent protection built in ? For the internals themselves, or indeed the external wiring etc ?
And likely it'd need both lines fused ?
Re: Full H-bridge
We are developing an external controller for them with a new piece of hardware to be able to handle the full current requirements
But the H Bridges on the S7plus will deal with it if calibrated correctly with just P and D term
Re: Full H-bridge
I'm trying to control the same eWastegate with an old Syvecs H-Bridge because I don't have enough outputs, but it looks like it 's not working...
Re: Full H-bridge
Okay, trying to get this working but no luck. I´m seeing only 5 volts coming out from pins 21 and 22 (H-Bridge 3 and 4). I suppose this should give me 12 volts. Wastegate control1 is assigned under I/O configuration to "SLAVE1 OUT #13". DBW is connected to pins 4 and 30 (H-Bridge 1 & 2) and works great.
So why only 5 volts from pins 21 and 22?
EDIT: Under Wastegate control, Output Drive Type is is set as "Full-Bridge". But could the wastegate control limit the voltage output when engine is stopped and only ignition/key is on? I have set wastegate control enabled when throttle position is 0, engine speed 0 and bap offset is 0.
There´s dedicated function under Supercharger Bypass Valve as "Enabled When Engine Stopped" but not under Wastegate control.
Re: Full H-bridge
Under what duty/freq is the output you're saying there is 5v ?
And how are you determining this voltage ? Really, on an active H-Bridge PWW output....the only way to measure what is actually happening is with a scope.
5v on a multimeter could simply mean it's around say 40-50% duty.
Re: Full H-bridge
Thanks for your input. You´re right, it is PWM, but multimeter is showing constant 5.62 volts from both outputs and the Wastegate valve do not move at all even though I change duty from 100 to 0 % or somewhere between. BUT looking at the conditions on software, it enables wastegate control when engine rpm and TPS is exceeding the set value. Hence I am just in heat of installing engine, I cannot run it, so naturally I can´t get any rpm. Setting rpm 0 and tps 0 % does not perhaps help as the rpm should exceed 0.stevieturbo wrote: Fri Feb 12, 2021 2:35 pm Under what duty/freq is the output you're saying there is 5v ?
