The S6GPPlus has an integrated slave which expands the capability relative to the S6GP. Below is a list of hardware slave assignments :
Slave Analogue 1 : AS1
Slave Analogue 2 : AS2
Slave Analogue 3 : AS3
Slave Analogue 4 : AS4
Slave Analogue 5 : AS5
Slave Analogue 6 : AS6
Slave Analogue 7 : EGT2
Slave Analogue 8 : LAM1A / DENSO / LSU Lambda
Slave Analogue 9 : LAM1C / LSU Temperature
Slave Analogue 10 : LAM2A / DENSO / LSU Lambda
Slave Analogue 11 : LAM2C / LSU Temperature
Slave Analogue 12 : S6GPPlus Battery Voltage
Slave Out 1 : HBR1
Slave Out 2 : HBR2
Slave Out 3 : HBR3
Slave Out 4 : HBR4
Slave Out 5 : HBR5
Slave Out 6 : HBR6
Slave Out 7 : HBR7
Slave Out 8 : HBR8
Slave Out 9 : LAM1HTR
Slave Out 10 : LAM2HTR
Additionally, some or all of the additional inputs and outputs (up to #28) may be assigned to virtual pin - typically Slave Analogue 13-16 are used for vehicle speed inputs (read from an ABS unit over CAN bus). The allocation of these virtual pins are firmware dependant, which is itself vehicle dependant - not all vehicles have the same ancillaries and a combined list of all possible ancillaries would exceed the number of virtual pins available, hence that list is tailored to the specific application where the S6GPPlus is deployed.
S6GPPlus Slave Assignments
Jump to
- Syvecs Engine Control Systems
- ↳ General Syvecs Chat
- ↳ S6 GP/PnP Technical
- ↳ S6-I / S6Plus Technical
- ↳ S7-I | S7Plus | S7D Technical
- ↳ S8 Technical
- ↳ S12 Technical
- ↳ Syvecs Bluetooth Module
- ↳ Software
- ↳ Calibrations
- ↳ Technical Deposit
- ↳ Projects
- General Technical Forums
- ↳ Subaru
- ↳ Mitsubishi
- ↳ Toyota
- ↳ Nissan
- ↳ Porsche
- ↳ Dyno Talk
- ↳ Track Days
- ↳ VAG Technical
- Expanders
- ↳ X10 (Legacy - Gen1)
- ↳ X10 Gen2 Expander
- ↳ X20L Gen2
- ↳ X4 Gen2
- ↳ OEX - Oem Ecu eXpander
- Syvecs AWD Modules
- ↳ General Questions
- ↳ VAG MQB4 Range - Golf R7, Audi S3
- ↳ VAG MQB5 Range - Audi RS3 / TTRS
- ↳ Porsche 991.1 / 991.2
- ↳ Porsche 997.1 / 997.2
- ↳ Huracan / R8
- ↳ Nissan R35GTR
- ↳ Infiniti Q60
- ↳ Yaris GR Gen1
- ↳ CorollaGR / Yaris GR Gen2
- ↳ Generic AWD Module
- Syvecs Accessories - GPS | Bluetooth | KT8 | Wifi | WMI | DI12 | Lam2CAN
- ↳ Syvecs 50hz GPS / IMU Module
- ↳ Syvecs 100hz GPS / IMU Module
- ↳ Syvecs KT8
- ↳ KT8 Rev3 Standalone
- ↳ Syvecs Wifi Module
- ↳ Syvecs WMI Module
- ↳ Syvecs DI12
- ↳ Syvecs Lam2CAN
- Syvecs Dashes
- ↳ Syvecs TinyDash
- ↳ Syvecs Edition Plex Dashes
- ↳ Syvecs D5 Dash
- Enhancements
- ↳ Feature Requests
- ↳ Request for Comments
- JT Innovations
- ↳ Toucan Display
- ↳ General
- Feedback
- ↳ Website feedback
