Im Jack , from Aberdeen , i have a 2003 ford focus RS , it was running standard ECU for a few years but a few engine failures has high lighted the need for a better ECU , so iv bought a S6 GP.
its a bit of a dinosar in terms of computing power (no fancy diffs ect) but its a decent spec , running a full built motor , was up at 500bhp on the ford ECU reving to 7000rpm (couldnt get the ford ECU to rev higher , engine was built to rev to 8300rpm) has external oil pump , gtx30 , water meth injection , ID1000's , nortech manifold , full 3" system , all fiber kevlar body pannels ect
I dont plan on fitting it my self , im not the best when it comes to electrics , so will have the person thats mapping the ECU help me , but untill we get started i have a few questions
Will the zetec stock sensors work ? cam crank boost controler ect?
Im going over to COP , using toyota yaris coils , as i dont think the ECU can run fords wasted spark set up with out the need of an external ignition amp , right thing to do ?
I have a rather expensive Stack dash set up in the car, have various sensors that feed it aux info , this will all get bined and replaced with a little digi dash thats fed from the ECU , but i would like the ECU to be able to monitor the other imputs ? i currently have the stack ST747 sensors for the fuel and oil pressure , and the standard brass stack temp sensors , will these work with the new ECU or will i have to go over to syvecs spec ones?
also have a stack wide band fitted but im sure its a bocsh lambda , so am i right in saying il have to swap out to the NTK one?
Also have the stack digi EGT gauge , again will i be able to use the sensor to feed the ECU or will i have to buy a stack one?
below are a few photos of the sensors and a few of the car
IMG_7675 by Jack Strathdee, on Flickr
IMG_7680 by Jack Strathdee, on Flickr
IMG_7674 by Jack Strathdee, on Flickr
e3 by Jack Strathdee, on Flickr
IMG_7076 by Jack Strathdee, on Flickr
IMG_7085 by Jack Strathdee, on Flickr
IMG_7747 by Jack Strathdee, on FlickrLike i said i have very little knowlage of this kinda stuff , so please be kind!
