Hi
I downloaded the calibration software and S6 example calibration to play around with as I hunt for a suitable ECU for my car.
I see the Skyline CAS is supported, and I don't grasp all the settings in the custom trigger configuration. Is support for the 4-cylinder SR20 CAS sensor available?
Thanks in advance.
Support for SR20 CAS sensor
Jez
- Horsham Developments
Re: Support for SR20 CAS sensor
Not at the moment - we usually swap the CAS disk out for one similar to this: http://www.ebay.com/itm/AEM-30-8760-CAS ... 0725856700
Yes, that's easy enough to do.
Thanks.
Thanks.
Mark@Abbey M/S
Jez,
that disc works well then? or would it be better to go 36-1 with a phase sensor? Got a Sr20 project on the go @ the moment and looking at running it on a S6.
The best would be a missing tooth trigger disc on crank, and one phase tooth on cam. This needs a trigger disc and sensor install but if higher revving engine then it makes a difference.Mark@Abbey M/S wrote:would it be better to go 36-1 with a phase sensor?
Jez
The disk worked ok on my engine - I didn't attempt to measure any jitter caused by the chain flapping about / play in the cam/cas gear.
A proper crank wheel and cam phase setup would, in theory, work better - but I found on my car the disk was adequate.
Could somebody share a cal file using this AEM trigger disc?
Hi
Also looking for a calibration for the AEM SR20 disc please.
I looked at the RB26 one posted earlier for ideas, but need the angles for the SR installation.
