S6 Default Cal
LMS-EFI
S6 Default Cal
Post by LMS-EFI »
The link is broken for the latest S6 default cal. Can it be updated, please? Thanks!
Syvecs Staff - Cleaner
Re: S6 Default Cal
Post by pat »
Due to the number of different firmware versions, we no longer upload default calibrations.
You can easily create one for any version of firmware you have either connected to or have a firmware file (.exe) for. If you haven't already connected to an ECU of the desired version then simply run the firmware update file, even without a connection to the ECU, and it will install the profile needed to build a default calibration (it will of course fail to update the ECU because it is not connected but that doesn't matter). Once you have run the firmware update executable, you should now see that version appear as an option when you do File -> New in SCal. For firmware versions SCal has already seen before, entries will already exist when you do File -> New in SCal.
NB: Firmware update files can be found on the forum in the appropriate section (S6 or S8).
LMS-EFI
Re: S6 Default Cal
Post by LMS-EFI »
Got it! Cheers!
