Traction control
- Horsham Developments
Re: Traction control
Good innit
The fact it could deal with the motor in high boost, R888 tires and wet roads shocked me, what a noise as wellJez wrote:Good innit
How is yours setup Wez? Is it using an ign retard only or is there some sort of fuel cut in there as well? Any EGT feedback built into it to limit the retard duration?
Dan
Dan
It does use EGT feedback yes, but at the moment its based on fuel cut so not much coming into a affect, Ryan could add more info if you need it.Dan wrote:How is yours setup Wez? Is it using an ign retard only or is there some sort of fuel cut in there as well? Any EGT feedback built into it to limit the retard duration?
Dan
