5V outputs on S6PnP
RichardB
5V outputs on S6PnP
Post by RichardB »
Hi guys,
I was trying to add a second map sensor to monitor EGBP. When wired into the 5V output on B09 I was getting TPS sensor voltage errors and the car wouldn't start. As soon as the sensor is disconnected from B09, all goes back to normal. The ground was wired to the main ecu ground. Could it be that this is just one sensor to many for this 5V output? I thought there was a second 5V output, but can't seem to find it listed on the S6Pnp pinout. Can anyone point me in the right direction please?
Richard
Charlie
Syvecs Staff- Tea Boy
Re: 5V outputs on S6PnP
Post by Charlie »
Have you tried pin 9 on the aux connector on the rear of the board ?
RichardB
Post by RichardB »
Nope. Thanks Charlie, I'll give that a try.
RichardB
Post by RichardB »
Thanks Charlie, all sorted. :D
My oe ecu casing had only been cut away around the LAN port, so the AUX connector was not initially visible.
