Ign outputs
Gizmo
Ign outputs
Post by Gizmo »
Sitting here putting together some looms for S6 GPs to go into 4cyl Subaru's.
It occured to whilst doing it to look have a sniff in Scal to see if the spare Igniter outputs can be configured to do any other jobs, this appears to be the case. But is it ?
Also if this the case what current can they Sink ?
thanks ---john---
Syvecs Staff - Cleaner
Re: Ign outputs
Post by pat »
John,
Any spare output can be assigned to pretty much any function. If you wanted to drive a wastegate solenoid then so be it, BUT... the IGN outputs are low current TTL push-pull types, not the normal high current open collector type. We normally only use them for things that have a fairly high impedance / low current demand. Furthermore it would be wise only to drive resistive loads, not inductive or reactive. Typical "non-ignition" applications are driving the input to fuel pump controllers and the control input of an H-Bridge driver for DBW applications. We do also sometimes feed them into RC low pass filters to generate a pseudo-analogue output for devices that want linear drive.
If your application requires more than 40mA and/or is inductive/reactive then you will need to buffer the output. If you're low on outputs then a buffer is the best option, if you have spare outputs that can drive your application then better off using those.
Gizmo
Re: Ign outputs
Post by Gizmo »
Thanks for that Pat, now fully aware of what they are good for :)
Only contemplated it as I was wiring the S6 connector and thought they may be handy/usefull additions.
Seems they may well be :D
---john---
