I saw the thread about Windows 7 working, when SCal is put in Compatibility Mode, but trying this on my new Windows 7 64bit machine I cannot get a connection to the ECU.
I've tried various compatibilty modes including XP SP2 & XP SP3, Vista, Vista SP2 & Vista SP3
SNetServer will run in some fo the compatibility modes, but no network adaptors are ever found.
I am using the software downloaded from this forum.
Any ideas Pat?
Dan
Windows 7 64bit
Windows 7 64bit
Nissan S14a 200SX S6GP 395bhp 390lbft
Please contact me to add News stories to the Syvecs website
Re: Windows 7 64bit
The recommended solution for the moment is to install Windows XP 32 bit and run the software on that. On my own laptop I am running Ubuntu Linux in 64 bit mode on a Core i7 CPU but get the required XP 32 bit environment courtesy of Sun VirtualBox, which is a free download from here. It is available for many hosts, and does include USB support and accelerated OpenGL from the guest OS.
Re: Windows 7 64bit
I will be trying VirtualBox on a Windows 7 64bit install tomorrow, I will let you know how it goes.
Re: Windows 7 64bit
Hi Wez, downloaded Virtual box, see you tomorrow
Dan
Dan
Re: Windows 7 64bit
A big thank you to Wez:)
All working and connecting fine using XP via Virtual Box on a Win 7 64bit OS.
I'll leave Wez to explain any technical bits!
Re: Windows 7 64bit
Indeed it does, worked a treat with WinXP SP2 installed into a small virtual machine. Only thing required is the network has to be set to bridged not NAT under network options on the virtual machine.
I also installed the VirtualBox support pack
