CAN BUS Cal Switch
Steve
Re: CAN BUS Cal Switch
Post by Steve »
Future Toucan owner here then when this is implemented :)
Hurry up :mrgreen:
Syvecs S6 with aftermarket DBW setup on Greddy Style Intake manifold.
- SOLD 2017
Just a few weeks away :)
Steve
Post by Steve »
Would this also mean that options like Rolling anti-lag can be controlled by the CAN BUS or is it limited to Up/Down Cal/Trac Commands?
- SOLD 2017
als on/off and rolling als / pit limiter should be doable.
CAL up, CAL down, ALS request and CAL override. First 3 will be in Toucan for sure, hoping to add a CAL override button. Not sure if you can achieve what you need from those 4 things?
Steve
Post by Steve »
What would CAL override be used for?
- SOLD 2017
Steve wrote:What would CAL override be used for?
You can configure a specific CAL that is selected while CAL override is active. For example, an "overtake" button that temporarily increases boost compared to the usual CAL.
So anyhing you can set up in a dedicated CAL can be selected at the press of a button, regardless of which CAL you're currently running.
