Latest Firmware Releases
The Syvecs Lam2CAN is an 8 Channel Laboratory Grade NTK Lambda sensor interface with comprehensive onboard fault logic. It also includes dual dedicated exhaust pressure sensor inputs enabling compensation for the effects of exhaust pressure on the lambda measurement. Data from the Lam2CAN is then transmitted via CAN to provide fast and accurate data to engine control units and external dataloggers.
Locked
Changes since 1.8:
* USB DataLogging Support - https://youtu.be/bzvMUCqiv_0
Please ensure you are using the Latest Ssuite software which has USB support - viewtopic.php?f=8&t=122
Latest 1.10 Firmware
https://www.syvecs.com/downloads/LAM2CAN1-10-1.enc
Re: Latest Firmware Releases
Changes since 1.10:
* Support for Multiplexed frames
* Support for scaling and offer on RX frames
* Option to disable LTC CAN
Latest 1.13 Firmware
https://www.syvecs.com/downloads/LAM2CAN1-13-2.enc
Changes since 1.13.1:
* BugFix with Exhaust Pressure sensor Map lookup across banks
Latest 1.13.3 Firmware
https://www.syvecs.com/downloads/LAM2CAN1-13-3.enc
Locked
