Good afternoon, I have a problem. I have an s6 with firmware 1.5
I update the firmware to the latest available and it deletes the entire file. Then I try to write the previously saved file and it won't let me.
what is the solution?
thanks
firmware s6 problem
Re: firmware s6 problem
1.50 ?
That's pretty old.
So what do you mean it deletes the file ? What file are you referring to ?
https://www.youtube.com/watch?v=Pi1pp-XbQqw&t=3s
That's pretty old.
Hello
I mean that when updating the firmware, all the data from the file that is saved in the ECU disappears. To make the saved map work I had to go back to version 1.5
As is clearly detailed in the video I linked to, you need to upgrade the software version of your current calibration from 1.50 to whatever, to suit that of the new firmware version before it can be loaded into the ecu with the new firmware.gorlamotor wrote: ↑Fri May 26, 2023 6:25 am Hello
