Latest Base Map
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
Locked
Latest Base Map
The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
AwdBase_RS3 1.14.SC
(37.21 KiB) Downloaded 3523 times
1.15
1.15 Firmware Base Map
AwdBase_RS3 1.15.SC
(38.8 KiB) Downloaded 3257 times
1.18
AwdBase_RS3 1.18.SC
(42.89 KiB) Downloaded 3312 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_RS3 1.21.SC
(46.26 KiB) Downloaded 3203 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_RS3 1.23.SC
(51.46 KiB) Downloaded 3330 times
AwdBase_RS3 1.23 X4.SC
(51.46 KiB) Downloaded 3227 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_RS3 1.24.SC
(55.83 KiB) Downloaded 3129 times
AwdBase_RS3 1.24 X4.SC
(55.78 KiB) Downloaded 3203 times
1.25
AwdBase_RS3 1.25 X4.SC
(61.05 KiB) Downloaded 3226 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_RS3 1.27.SC
(66.84 KiB) Downloaded 1362 times
AwdBase_RS3 1.27 X4.SC
(66.87 KiB) Downloaded 1323 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_RS3 1.28 X4.SC
(72.44 KiB) Downloaded 937 times
Re: Latest Base Map
For use with 1.29 Firmwares
AwdBase_RS3 1.29 X4.SC
(72.89 KiB) Downloaded 1111 times
Locked
