This thread is for tracking the firmware builds of the AWD Audi MQB5 units. When a new release is available it will be added to the end of this thread.
Latest Firmware Releases
Re: Latest Firmware Releases
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_MQB4_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_MQB4_1-24-4.enc
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_MQB4_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_MQB4_1-25-1.enc
