Hi guys,
i've got a little problem. So far car is running nice but the Idle Control Valve doesn't really seem to do it's job so i wanted to check if i've set the Output Pins and Idle Stepper Config right. Car is running via Supra PnP Loom.
First of the Output settings:
Idle Speed Control 1 - PWM 05
Idle Speed Control 2 - PWM 06
Idle Speed Control 3 - PWM 07
Idle Speed Control 4 - PWM 08
Idle Stepper Control settings:
PWM Frequency - 3000hz
Length of Step Sequence - 4
Output 1 Step Duty - 100% - 0% - 0% - 100%
Output 1 Hold Duty - 0% - 0% - 0% - 0%
Output 2 Step Duty - 0% - 0% - 100% - 100%
Output 2 Hold Duty - 0% - 0% - 0% - 0%
Output 3 Step Duty - 0% - 100% - 100% - 0%
Output 3 Hold Duty - 0% - 0% - 0% - 0%
Output 4 Step Duty - 100% - 100% - 0% - 0%
Output 4 Hold Duty - 0% - 0% - 0% - 0%
Step drive Time - 10ms
Hold power delay - 100ms
Initialisation Direction - Close
Number of steps for Initialisation - 180
Number of steps - 160
Minimum Target in Crank - 65%
Minimum Target in Run - 40%
No matter what i set in Idle Control(bypass duty/Target Speed) i can't get the Revs up above 800rpm it just varies between 600 and 800rpm depending on setting.
Is it the Settings in the Syvecs or the Valve itself?
Supra TT ICV Outputs and Config
Re: Supra TT ICV Outputs and Config
<clip>
</clip>
At least - driving frequency setting is way too high, if Toyota specs for the idle/auxiliary air valve are not known, try values between 30-100 Hz. Stepping sequence and hold power delay might be worth to verify also.
</clip>
I'll give it a try, outputs are right?
I tried setting the PWM Frequency between 30-100hz every time the ECU said invalid Frequency and didn't want to start...
Okay i've switched the Outputs for the ICV:
Instead of
it is
Idle Speed Control 1 - PWM 07
Idle Speed Control 2 - PWM 05
Idle Speed Control 3 - PWM 08
Idle Speed Control 4 - PWM 06
It seems to be working now and i can adjust idle BUT i can't get it lower than ~800rpm. Any ideas?
Instead of
it is
