Latest 50hz GPS Firmware
Posted: Mon Mar 15, 2021 5:43 am
by Ryan.g
This thread is for tracking the firmware builds for the Syvecs 50Hz Gps Modules. When a new release is available it will be added to the end of this thread.
A manual on how to flash the latest firmware is here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
1.2
Posted: Mon Mar 15, 2021 5:50 am
by Ryan.g
Firmware 1.2 of the 50Hz GPS Module is attached below. This firmware will be loaded onto new sales from the 10/3/21 if you purchased before then we recommend updating.
Please use the Syvecs Updater program to load the ENC file. Guide here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
ENSURE the GPS is sealed again if using in harsh environments with a silicon based sealant
The 1.2 Firmware fixes the following issues:
* Added Support for Bosch MM5 (see manual for Can Info - http://www.syvecs.com/downloads/Syvecs_ ... Module.pdf)
* Added Support for Motec M1 Series (see manual for Can Info - http://www.syvecs.com/downloads/Syvecs_ ... Module.pdf)
* Fixed Uart Boot Issue
* Faster Wakeup of Device on Canbus
1.3
Posted: Tue Dec 07, 2021 5:59 pm
by Ryan.g
Firmware 1.3 of the 50Hz GPS Module is attached below. This firmware will be loaded onto new sales from the 18/11/21 if you purchased before then we recommend updating.
The 1.3 Firmware fixes the following issues:
* GPS Chip firmware error which would cause the unit to not boot correctly
1.4 Firmware
Posted: Thu Aug 18, 2022 10:06 am
by Ryan.g
Firmware 1.4 of the 50Hz/100Hz GPS Module is attached below.
The 1.4 Firmware fixes the following issues:
* Added support for 100hz new hardware
* Signed issue fixed on heading
* Speed Jumping issue fixed when stationary at high altitudes
1.5 Firmware
Posted: Thu Feb 16, 2023 8:01 am
by Ryan.g
Firmware 1.5 of the 50Hz/100Hz GPS Module is attached below.
The 1.5 Firmware fixes the following issues:
* BugFix for 100hz IMU Data being 90deg out with New IC
1.6 Firmware
Posted: Sun Feb 25, 2024 3:27 pm
by Ryan.g
Firmware 1.6 of the 50Hz/100Hz GPS Module is attached below.
The 1.6 Firmware fixes the following issues:
* Improvements for signal decoding in areas where sat data is limited
Womens In Your Town - No Verify - Anonymous Sex Dating
Posted: Sun Mar 08, 2026 12:08 am
by Bennett753
Private Girls From Your Town - No Selfie - Anonymous Adult Dating
https://PrivateLadyEscorts.com
Private Lady In Your Town - Anonymous Sex Dating - No Selfie
NEW GIRLS
Vladochka
KATIE PEARL
Bella
Amber
Sam
Kate Katysha
Natsumi
