Keeping a strong suction power all the time is essential when using the vacuum machine to clean your house. Even when you are using Best Vacuum Cleaner, you need to clean the filter in a timely and good manner. The way you clean the vacuum filter and beater bar after use will ensure the air moves freely through the machine. The cleaning task is not difficult but you need to do it in the right way to obtain the best result. If you are using a washable dust bin, this article is going to be very useful.
1/ When to empty and when to wash the dust canister?
- Empty the dust canister – When and How?
- Wash the dust canister – When and How?
2/ When to wash and replace the vacuum filter?
Best Vacuum Cleaners come with washable and reusable filters. It is more environmental-friendly by just washing it and replace it after 3 to 6 months depending on its workload and the size of your house.
- Wash the vacuum filter – When and How?
Tip: your good vacuum cleaner may have a special brush for cleaning the filter. It helps the cleaning task to be more time-efficient and effective.
- Replace the vacuum filter – When and How?
To sum up
Bagged vacuums are now replaced by canister vacuums. This is the reason why you should know the right way to clean and replace the dust canister and the filter of your machine. Accumulation of dirt and dust in the machine can result in clogging and loss of suction power. A very dirty filter can, in the long run, damage the whole machine. It will be big cost damage for you. Just a few simple steps you can maintain the peak cleaning performance of Top Rated Vacuum Cleaner in the whole lifespan of the machine.
