Motec Dash Configs
henryevans
Motec Dash Configs
Post by henryevans »
The ultimate guide to clean your good vacuum cleaner
Keeping a strong suction power all the time is essential when using the vacuum machine to clean your house. Even when you are using Best Vacuum Cleaner, you need to clean the filter in a timely and good manner. The way you clean the vacuum filter and beater bar after use will ensure the air moves freely through the machine. The cleaning task is not difficult but you need to do it in the right way to obtain the best result. If you are using a washable dust bin, this article is going to be very useful.
1/ When to empty and when to wash the dust canister?
  • Empty the dust canister – When and How?
Most dust bins of modern vacuum cleaner are translucent that allow users to check easily how full the dust bin is. When you see the bin is nearly full, you should empty it to make the machine ready for the next use. Depending on the size of the bin and how often you vacuum your house, you need to empty it more or less often.
  • Wash the dust canister – When and How?
Apart from emptying the bin, you need to wash it to ensure the best cleaning performance at all times. You can simply clean the dust bowl with soap water; then, let it air dry completely before place it back in the machine. Please remember that you must never let any liquid get inside the machine after a thorough clean.
2/ When to wash and replace the vacuum filter?
Best Vacuum Cleaners come with washable and reusable filters. It is more environmental-friendly by just washing it and replace it after 3 to 6 months depending on its workload and the size of your house.
  • Wash the vacuum filter – When and How?
Whenever you recognize your vacuum machine loses suction power, it is time to check and clean the filter with soap water. Let the filter air-dry completely before returning it to the machine to ensure no water gets inside the motor.
Tip: your good vacuum cleaner may have a special brush for cleaning the filter. It helps the cleaning task to be more time-efficient and effective.
  • Replace the vacuum filter – When and How?
It is advised to replace the machine filter every 3 to 6 months to keep peak performance. You can set up a reminder on your mobile phone to remember.
To sum up
Bagged vacuums are now replaced by canister vacuums. This is the reason why you should know the right way to clean and replace the dust canister and the filter of your machine. Accumulation of dirt and dust in the machine can result in clogging and loss of suction power. A very dirty filter can, in the long run, damage the whole machine. It will be big cost damage for you. Just a few simple steps you can maintain the peak cleaning performance of Top Rated Vacuum Cleaner in the whole lifespan of the machine.
Lqqk
Re: Motec Dash Configs
Post by Lqqk »
+1. This would be very useful.
Jason Bentley
Post by Jason Bentley »
I can help you with a dash config. I would need to know the contents of your datastream and depending on your goals with the Motec dash, I would most likely have some more questions for you. If you're interested, email me at jason@bendcalibration.com
