				Latest Firmware Releases
				Posted: Mon Aug 22, 2022 6:31 am
				by Ryan.g
				Firmware 1.4 of the 50Hz/100Hz GPS Module is attached below.
Please use the Syvecs Updater program to load the ENC file. Guide here
http://www.syvecs.com/downloads/Syvecs_Updater.pdf
ENSURE the GPS is sealed again if using in harsh environments with a silicon based sealant
The 1.4 Firmware fixes the following issues:
* Added support for 100hz new hardware
* Signed issue fixed on heading
* Speed Jumping issue fixed when stationary at high altitudes
				1.5 Firmware
				Posted: Thu Feb 16, 2023 8:01 am
				by Ryan.g
				Firmware 1.5 of the 50Hz/100Hz GPS Module is attached below.
The 1.5 Firmware fixes the following issues:
* BugFix for 100hz IMU Data being 90deg out with New IC
				1.6 Firmware
				Posted: Sun Feb 25, 2024 3:25 pm
				by Ryan.g
				Firmware 1.6 of the 50Hz/100Hz GPS Module is attached below.
The 1.6 Firmware fixes the following issues:
* Improvements for signal decoding in areas where sat data is limited
				1.7 Firmware
				Posted: Wed May 22, 2024 5:54 am
				by Ryan.g
				Firmware 1.7 of the 50Hz/100Hz GPS Module is attached below.
* BugFix with IMU data for Bosch MM5 Stream
https://www.syvecs.com/downloads/SyvecsGPS_1.7.enc
				1.9 GPS Release
				Posted: Fri Sep 06, 2024 2:46 pm
				by Ryan.g
				Firmware 1.9 of the 50Hz/100Hz GPS Module is attached below.
The 1.9 Firmware fixes the following issues:
* BugFix with LatG and LongG CAN transmission drop
https://www.syvecs.com/downloads/SyvecsGPS_V9.enc
[*]Custom version for dual 500kb below[*]
https://www.syvecs.com/downloads/Syvecs ... CUSTOM.enc
