Custom map for DCCD control?
secure
Post by secure »
Just updated the new firmware and it looks amazing! I watched the help video but I'm a bit lost between AUX PWM FAN FUEL IGN output things..
On my configuration FUEL5 was used for DCCD control. Can I make a 3D custom map for DCCD by using my YAW sensor, TPS versus DPCDuty? I'm confused between the outputs..
Re: Custom map for DCCD control?
The Brake by wire and Fan assignments can all be turned into Custom maps.
So you would first click V, C to get into the customising window on the latest software and firmware.
Here you would want to use a Fan output which is setup for PWM and has a (PWM) assigned... Like Fan6
Then on the Output Use, Change the names to Say DCCDControl
After select the Parameters for the Axis
So Yaw on X and TPS on Y
Then press esc and the proceed option
After click V, C again and go down to Output Functions - Fan6
Here you can enter the PWM Freq and adjust the breakpoints for the Map
When finished move the Fuel5 assignment to Fan6 and off you go
secure
Post by secure »
I did all of them and left my brain at that finish. I couldn't think to move fuel5 to fan6.
All my confusion gone now =) Thanks Ryan!
