BAC Idle Frequency?
BAC Idle Frequency?
Where does one adjust the frequency of the PWM output for BAC idle control? Only setting I can find is under Idle Stepper Control > PWM Frequency. Thanks!
Re: BAC Idle Frequency?
Have you looked at the "Throttle Bypass Valve" menu?
The output should also be configured as "Throttle Bypass valve A" unless you have a 3 wire valve in which case you can configure outputs A and B for each side in a push/pull setup.
Thank you. Makes perfect sense once it's right in front of you.
