Latest Firmware Releases
Latest updates and support on the DI12 Module
Latest Firmware Releases for the Syvecs DI12 which have the USB Adjustment port as seen below
Re: Latest Firmware Releases
Firmware 1.1 of the Syvecs DI12 Module is attached below.
Please use the Syvecs Updater program to load the ENC file. Guide here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
This Firmware is only for DI12 Modules which has the USB plug on the back of the Unit with removable HEX Plug
The 1.1 Firmware adds Scal software support to allow configuration of the DI12 Current levels and users must load a 1.1 base map found in the base map section after the firmware is loaded.
https://www.syvecs.com/downloads/DI12_1-1-1.enc
