install manual for S7
Moderator: Wez
CT9A
Post by CT9A »
Is there a install manual for S7, the current manual does not work for S7.
Re: install manual for S7
Im currently updating the firmware so the S7 Fixed stream can be used on the BT Module and it makes life really easy . For now just put in the custom can content from a S6 into the transmit area and enable option to duplicate Custom Can on Rs232
Then in the app line up the Content to match
TurboRookie
Post by TurboRookie »
any luck with the manual? Can I use the fix stream or should i dive into custom can?
Cheers!
