This thread is for tracking the firmware builds of the AWD R35GTR units. When a new release is available it will be added to the end of this thread.
Latest Firmware Releases
1.14.2
This is the first public release level
Firmware Version 1.14.2 - www.syvecs.com/downloads/AWD_R35GTR.enc
1.15
Version 1.15 contains the following updates
*Change Light Output Pin (HBR4)
*Drive ratio calculation for Gear detection on Manual Trans cars
*Enable Gear Detection from Drive Ratio option
*Change Light Min Speed
*Change Light RPM
*Change Light Min Tps
Firmware Version 1.15.2 - www.syvecs.com/downloads/AWD_R35GTR.enc
*Change Light RPM
1.18 Firmware
Changes since 1.15
1.18 - Added simple Map locking and Restriction option. - Press C, F inside a map
Firmware Version 1.18 - www.syvecs.com/downloads/AWD_R35GTR_1-18-1.enc
Changes since 1.15
1.21 Firmware
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_R35GTR_1-21-1.enc
Changes since 1.18
1.23 Firmware - X4
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_R35GTR_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_R35GTR_1-23-1.enc
Changes since 1.21:
1.23.3
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_R35GTR_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_R35GTR_1-23-3.enc
1.24
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_R35GTR_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_R35GTR_1-24-4.enc
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_R35GTR_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_R35GTR_1-25-1.enc
Re: Latest Firmware Releases
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/AWD_R35GTR_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/X4AWD_R35GTR_1-27-1.enc
