Is it even possible to use an analogue sensor for triggering a clutch position function on an S6? The inputs available seem to only allow a switch.
How would you do that? I cant see it as an option in the S6 software? Or are you suggesting to use the high and low trigger voltages and not a proper pressure sensor linearisation?stevieturbo wrote: ↑Mon Apr 18, 2022 2:18 pm
But as the "clutch switch" can be defined based on clutch pressure/position....I would assume it could be used ok with a linear pot ? and is a variable you could play with.
beat me to it.stevieturbo wrote: ↑Mon Apr 18, 2022 2:21 pm And you seem correct...I do not see clutch position or pressure in the S6.
