Hello All,
I am looking for some advice/assistance in connecting a Syvecs Bluetooth Module to my S6PNP on my Subaru MY99.
The Bluetooth Module install guide advises that Pin4 is Ground, Pin5 is RS232 TX, Pin6 is RS232 RX and Pin 7 +12v Power Batt/ECU.
Looking at my Syvecs ECU there are several connectors on the rear, the one I'm interested in is the Comms RJ11/RJ25 connector for CanBus/RS232.
Is there a cable I can get to help connect the RS232 RX&TX from the CanBus RJ11/RJ25 port to the Bluetooth module ?
Any help or guidance is appreciated.
TIA
CharlesTuna
Subaru MY99/00 S6PNP & Syvecs Bluetooth Module help needed
CharlesTuna
Re: Subaru MY99/00 S6PNP & Syvecs Bluetooth Module help needed
Charles, did you get and answer on this?
I also have the RS232 pins already taken up by a Comms connector (in my case an RJ45).
Ideally a cable from this to the bluetooth would save a lot of trouble !
