CANBUS control of TC
Steve
Post by Steve »
I see we are now able to alter CALs by CANBUS (Toucan or Syvecs Bluetooth), would it be possible for the TRAC to be altered by CANBUS as well?
For those of use who don't have spare inputs this would help out. (or is that just me! :D)
Toyota Supra BoostLab S366HF - 821 rhhp / 644 ftlbs - Mapped by Ryan
Syvecs S6 with aftermarket DBW setup on Greddy Style Intake manifold.
- SOLD 2017
pavlo
Zen Performance
Re: CANBUS control of TRAC
Post by pavlo »
You mean TC?
No not at the moment, but it's not out of the question.
What is your I/O out of interest? If you've gone DBW then that eats up 4 inputs right away!But if you've got a phase input and seperate VVT input you can probably save one there.
Steve
Post by Steve »
Yep, I mean TC.
Inputs I use are as follows...
Air Charge Temp
Cam Phase Sensor
Crank Position
Engine Coolant Sensor
Engine Oil Pressure
Engine Oil Temperature
Fuel Pressure
Load Cell for AC
Manifold Pressure
Pedal Position A
Pedal Position B
Throttle Position A
Throttle Position B
Speed Sensor Front Left
Speed Sensor Rear Right
Speed Sensor Rear Left
EGT is on the K Type input
Lambda on Dedicated input
Outputs are as follows....
Brake by Wire (AC)
Drive by Wire 1
Fuel Pump
Lambda Heater
Tacho
Wastegate Control
Inj 1
Inj 2
Inj 3
Inj 4
Inj 5
Inj 6
Ign 1
Ign 2
Ign 3
Ign 4
Ign 5
Ign 6
Knock sensor on there aswell.
- SOLD 2017
pavlo
Zen Performance
Re: CANBUS control of TC
Post by pavlo »
Hmmm, you are pretty maxed out!
An expander might be worth considering, but for now a Toucan with cal up/down can give you 12 positions which should allow for a few TC settings.
However, in the not too distant future I hope there will be a few more easy can inputs.
Steve
Post by Steve »
TBH I would only want TC off and just a couple of increased assistance settings, so 3-4 at a maximum.
The main CALs would be a max of 8 settings.
- SOLD 2017
pavlo
Zen Performance
Post by pavlo »
So be creative with your cal settings for now.
Steve
Post by Steve »
So I can use the 1 CAL switch to also control TC settings?
Just had a quick look over the software, couldn't see how to do this?
- SOLD 2017
pavlo
Zen Performance
Post by pavlo »
By Default the TCSelect will change with CALSelect. So without a dedicated TC select switch, in CAL12 for example you will be in TC12.
Steve
Post by Steve »
I did usd to have a TC switch so I guess I need to change it back to the default setting to do this?
- SOLD 2017
Does the bluetooth module allow TC, LC and CAL select settings ?
ie using it and an appropriate app would free up some inputs
Return to “Feature Requests”
