Sensors needed
karlosg
Sensors needed
Post by karlosg »
Ok , I need the following sensors , Please advise where to get them and type if necessary :
Air temp
oil pressure
oil temp
water temp
egt
wideband ( i believe NTK type ? )
Also Can you connect oil temp , oil pressure , water temp etc directly to the ecu?
Thanks in advance
karl
Jez
Horsham Developments
Re: Sensors needed
Post by Jez »
Hi
Was it you I spoke to today?
You can get most of those from here: http://shop.vems.hu/catalog/index.php?cPath=1_12
You can connect most of the sensors directly to the ECU - just configure them as thermistor.
Jez
