Cam and crank sensor setup
gaz@gr
Post by gaz@gr »
What is the sync scope voltages ? i was told each line was .5v but have seen a pic showing each line is 1 v .
after reading several conflicting ideas i thought i would just ask.
At this time i am running a 60-2 crankwheel and a phase sensor picking up both phases i will post a sync log later .
The car is running car in 360 deg atm , but i am stuggling to get 720
I dont want to keep hassling paul blamire as he helps enough (thanks paul ) i will be on phone later ;-)
will email these over asap but i just after a idea for myself for future issues .
pavlo
Zen Performance
Re: Cam and crank sensor setup
Post by pavlo »
On the sync scope each line is 1v.
But if you are looking at a 5v bipolar in scal as a gauge it squashes +/- 5v to +/-2.5 volts, therefore +1v on an Scal gauge really represents +2v on the sensor, and would read +2v in the sync scope.
So the chances are you haven't been told what you thought you had.
pavlo
Zen Performance
Post by pavlo »
Also check here for some more info on threshold voltages:
viewtopic.php?f=10&t=483
gaz@gr
Post by gaz@gr »
Thanks for your time again paul .
got 720 deg sync ready for mapping now :-)
gaz@gr
Post by gaz@gr »
Car went out on first event and thanks to Paul for his help we managed a 1st place
Thanks Paul for your help
pavlo
Zen Performance
Post by pavlo »
No problem!
