Finally our Dash2 is working,after swapping the S6 for CANbus S6Pnp,we can stream some function like Boost,RPM,CAL position switch,AFR,Water temp,speed is hard wired via RT speed sensor to the DASH2,Some other function we will stream later on when we plug the other sensors(thanks to TimH@JT Innovations) such as Oil temp,Oil pressure,Air temp plus Fuel pressure and we would like to stream too EGT.
Now about the issues with CAN,how to say,we have small problem on side of the AFR(Lambda),which sometimes lock up on the 14.5(usually after few miles and sometimes will work again,but sometimes stay there for while),when i'm looking at logs and AEM Uego everything working on this side,but doesn't work on the DASH2.
I'm not sure if its problem on side of the Syvecs Custom CAN or DASH2,from several reading seems there is problem with refresh/update rate,can someone will point me in right direction where is or what needs to be changed
Thanks for any help guys
Jura
