I've looked through the various threads on here, and I think that the consensus is that the L2H2 is the only lambda sensor that is a) available and b) likely to work as expected on the S6PnP. Is that right?
If so, where is a good place to get one? And what are the connector types I need both at the ecu end, and for the lambda itself?
