trouble going from FW 1.74 --> 1.79
Posted: Mon Sep 11, 2017 3:29 pm
by dr_jones
Ran in to an issue today going from FW 1.74 --> 1.79 on the S6plus.
Seems related to 'sync out'the error I get once at level 1.79 is:
SYNCOUT : unknown pin : 65535
*** Boot code assuming control ***
Not had this issue previously between firmwares - and I see from the FW notes that there are some sync out changes:
-9..12 cylinders allowed but for fuelling only (ign, knock, sync out ignored)
-Sync Out Output - Internal Use only
...not a show stopper insofar as I can (and have) roll back to 1.74 - but I'd be interested in hearing if anyone has any ideas on this.
Re: trouble going from FW 1.74 --> 1.79
Posted: Mon Sep 11, 2017 5:58 pm
by Slowie
I guess this is happening after you loaded your CAL after flashing?
Nothing undefined in the IO config?
Posted: Mon Sep 11, 2017 6:32 pm
by dr_jones
Yep - converted my cal to 1.79, flashed FW to 1.79 - loaded from disk - all apparently successful - however checking further in 1.79 I have
Outputs : Sync Out as UNDEFINED - which I guess is the issue - thing is its not there at all (at least not that I can see) in v1.79 and my only choices are NOT CONNECTED (I'm guessing this is the only valid choice) or IGN 1 thu 6.
I've not had a chance to go back and test with Sync Out defined as NOT CONNECTED yet - but will do - any idea what is actually is?
Posted: Mon Sep 11, 2017 6:37 pm
by Slowie
That would be the error, yes. None of your I/O must be UNDEFINED. Change all UNDEFINED items to NOT CONNECTED, if not in use.
No, I am intrigued as to what it does, but don't know either. It might output sync status or simply pulse once per engine cycle, once synced up.
Posted: Mon Sep 11, 2017 7:58 pm
If it says internal use only, it's maybe something to do with comms between the expander and ecu on the plus ?
Either way, work through and ensure I/O's are all good and proper.
Posted: Mon Sep 11, 2017 9:44 pm
by dr_jones
Will do - also interesting to see cylinders 9 thru 12 listed there - what with this being a S6+ and all...
Posted: Mon Sep 11, 2017 10:02 pm
dr_jones wrote:Will do - also interesting to see cylinders 9 thru 12 listed there - what with this being a S6+ and all...
software is generic though for all models, and you can still pair outputs to more than one cylinder, eg batch fire etc
Posted: Tue Sep 12, 2017 8:19 am
by dr_jones
Ah ok - thanks - I did not realise that.
