pin 2 fuel pump control bosch 044
Posted: Fri Mar 31, 2017 3:29 pm
by vxt5
hi
help needed
been trying to to get the fuel pump to switch on when ign turned on
could someone please tell me what the parameters should be set at to use pin 2 as a trigger for a bosch 044 pump
im controlling the pump via a SSR
does the pwm pull to ground or send out 5v (need to get my head around this bit)
also this pump is on a non return system so it will be controlled via pressure switch so help with parameters would be great
im totally new to this so any help would be much appreciated
regards
matt
Re: pin 2 fuel pump control bosch 044
Posted: Fri Apr 28, 2017 4:22 pm
by Mark_r33
This similar thread is probably worth a read, in case you haven't solved this yet;
viewtopic.php?f=6&t=907
Posted: Fri Apr 28, 2017 5:50 pm
Aux 1 will pull to ground
Haltech give a decent drawing of how to wire things up, although they do omit a flyback diode which would be a sensible idea across the motor
http://www.haltech.com/wp-content/uploa ... 030202.pdf
Most of the settings should be fairly self explanatory and just do a bit of testing.
