Starting Config
Posted: Thu Jan 05, 2017 12:09 pm
by dr_jones
This morning - I was compelled to review by starting configuration due to a flooding issue.
Now in all honesty this is the first time I've really dug into this topic (previously I'd had trouble free starting down to around 5 degrees C)
I note that several of the tables have a (1) and a (2) - however I can;t seem to find either a help text on these or anything on the manual - EG:
Preliminary Fuel Injection 1 - f(ectMax)
Preliminary Fuel Injection 2 - f(ectMax)
Base Fuel Injection 1 - f(tps1)
Base Fuel Injection 2 - f(tps1)
Ignition Angle 1 (BTDC) - f(rpm)
Ignition Angle 2 (BTDC) - f(rpm)
Secondary Ignition Angle 2 (BTDC) - f(rpm)
The funtion of each seems clear - however which table is actually selected and why seems less so.
Can anyone shed any light on this?
-Ed.
Re: Starting Config
Posted: Thu Jan 05, 2017 1:31 pm
by Slowie
You select between maps 1 and maps 2 using the Cal switch. It is configured in Calibration Switches->Starting->Starting Maps Select
If you select 1, all the "1" maps are used. If you setup the Cal position 2 to use maps 2, all the maps with suffix 2 will be used during starting.
Re: Starting Config
Posted: Thu Jan 05, 2017 2:26 pm
by dr_jones
Thanks!!
