Starting but not 'running'.
Posted: Thu Nov 10, 2016 2:17 pm
So I've now got to the point where the car is starting - but dies after say 2 seconds.
Doesn't seem to matter what the throttle position is - (though starting *does* require a little throttle - irrespective of throttle bypass min duty cycle).
I'm guessing fuelling(?) i.e. fuelling is somewhere near whilst cranking but once runMode is 'Run' things are going south.
Thing is as the period to capture data is soooo tiny I'm struggling to get anything to go on.
Am I best just to bump up the low load fuelling and see if I get something better or is there a some other function that's likely to be causing this issue?
-Ed.
-Ed.
