Cruise/Volume s.wheel buttons
Posted: Wed Jan 20, 2016 10:18 pm
by secure
Hi!
Can Subaru cruise and radio buttons used as an Syvecs input say "rolling start" or "calsw" ?
Re: Cruise/Volume s.wheel buttons
Posted: Thu Jan 21, 2016 10:25 pm
The cruise buttons are normally connected to the OEM ECU on the later DBW models. On the earlier cable throttle models the cruise was implemented by a separate unit which actuated a secondary throttle cable - in that case you wouldn't be able to pick up the cruise buttons at the ECU. I don't recall seeing an OEM wiring schedule where the radio buttons go to the ECU but perhaps on the late model CAN bus cars there may be a message that could be picked up but it's not something we've actively looked for.
Posted: Fri Jan 22, 2016 8:40 pm
by secure
Actually I would like to add those oem buttons for my steering wheel for some function but not sure how do they work.
Posted: Sat Jan 23, 2016 10:47 pm
Audio buttons are like a CAL switch, with a resistive divider chain between pins 4 and 5 of the connector. The audio system does have a low speed CANbus system but this is not connected to the ECU.
Cruise control buttons also have a resistive divider between pins 6 and 7, with the main on/off switch between pins 8 and 6. No CANbus - connected direct to ECU.
Posted: Sun Jan 31, 2016 11:42 pm
by secure
Great info thanks!
