Running a toucan and dash 2 on an S6
Posted: Mon Aug 31, 2015 7:28 pm
by Hodge
Hi Guys
Im fitting an S6 into a supra and want to run a toucan and Dash 2 and could do with a little advice.
Now the Toucan is plug and play play via canbus with an Ethernet cable. My question is how do I connect the Dash 2 in. Will it just be a case of tapping into the can high and can low pins on the syvecs loom.
cheers
John
Re: Running a toucan and dash 2 on an S6
Posted: Mon Aug 31, 2015 7:42 pm
CANbus is "multidrop" so you would daisy chain the 3 things together.
Toucan as an extra connector on the back with CANbus on it, so you could pick it up from there (I can send you the connector with some wire tails if you call the office 01305 534535) and take it to the Dash or, as you say, tap into it at the S6.
Pedantically, each end of the bus should be terminated. I believe the S6 provides a termination by default so it really ought to be at one end, so the first method is technically better; although CANbus is pretty tolerant so you may not have any problem.
You will also need the CAN adapter for the Dash 2.
I imagine the actual data needed by the Dash will be different to the default Toucan setup in the S6 - not sure if it can be edited for the Dash so you may need to adjust the Toucan config to match that needed for the Dash.
Posted: Mon Aug 31, 2015 7:55 pm
by Hodge
Hi Ti
Thanks for the fast reply. The daisy chain idea sounds perfect. I already have the canbus adaptor for the Dash 2, so am I correct in thinki ng I just need the extra plug for the back of the Toucan and im good to go?
John
Posted: Mon Aug 31, 2015 9:18 pm
Yes :)
Posted: Mon Aug 31, 2015 10:06 pm
Could you run the Dash2 via serial from the Syvecs ?
Posted: Tue Sep 01, 2015 11:42 am
by Wez
The Dash2 can adapter is also adjustable so in your custom CAN profile just select the data you want for the Dash2 and Toucan and configure each device to suit ;)
Posted: Tue Sep 01, 2015 1:52 pm
by Hodge
This will work even if I daisy chain the 3 units as Tim said wont it Wez?
