Switched battery feed
Posted: Sat Feb 07, 2015 3:01 pm
Hi all, I am trying to workout how to connect a 12 volt ignition switched power feed to 2 analogue/digital converters for the abs sensors and an EGT sensor amplifier. All these are very low power consumption.
I assumed I could tap into the S6 Vbatt on pins 19-21 but not sure how these are connected through the syvecs loom adapter which would have supplied power to the oem 2JZGTE ecu.
Would it be best just to run another wire from the ignition switch for this?
