No Start !!
Posted: Tue Feb 18, 2014 5:54 pm
Hello guys.
Today I went to start up the drag car and the starter tured normally but without a hint of engine trying to start up. Engine sat for about two months without starting as i had
gearbox out so I couldnt start it up.
So as usual I pluged up laptop and in Scal syncstate was showing 360, and not 720, Run mode= STOP, and syncfault= long tooth Gap. RPM reading was showing 180-200rpm.
Then i suspected the cam sensor so I put another one without success, then changed the crank sensor also without success. Checked wiring of crank and cam and all is good.
All other sensors showing good values and working normally.
Later on the day, and this is fishy....rpm reading started to show zero and so i took out oscilloscope to check signal and near ECU plug both Crank and Cam and showing good signal.
I am suspecting that the ecu firmware has corrupted somehow, but only on the triggering maybe? Can it happen?
Thanks for help.
Thanks for help.
