Driven speed reading
Posted: Thu Oct 24, 2013 7:12 pm
Hi, I am trying to make the driven speed reading to match the actual speed while on the dyno but cant make it to match.
The speed input is from the stock Honda VSS hall sensor mounted on the transmission.
I have measured the tire circumference and tried changing the number of teeth to match speed to dyno but no success.
Input config is thermistor, and filters off.
Also i noticed that on Sview when it reached 155mph the reading stayed flat at 155mph even though the speed went higher.
Do you have any idea what can I do please?
Thanks alot.
Thanks alot.
