				Gt4 using caldina cam and crank sensors starting problem.
				Posted: Thu Sep 19, 2013 10:24 pm
				by wrxbart
				As above we've got a celica gt4 running a caldina engine including the caldina crank and cam sensors. We're having trouble getting it to run on the S6GP. We've had it started and in 720 sync but it backfires on starting and engine stops turning over like the ignition timing is too advanced. Also when we've had it running and it gets up to temp if you shut it of it will not start again until cold. Any help would be greatly appreciated as were banging our heads together now.
				Re: Gt4 using caldina cam and crank sensors starting problem.
				Posted: Sat Sep 21, 2013 8:13 am
				by Ryan.g
				Sounds like its on the wrong Cam signal (G2) and wiring on wrong phase
My Suggestion to check is
Go to Scal - DEVICE - CONNECT - hit OK - STARTING - MiNIUM ENGINE SPEED FOR 720 --- Set this at 9000rpm to stop it going into 720 and see if it starts ok then...
				Posted: Sat Sep 21, 2013 1:21 pm
				by wrxbart
				If it does then what next? Thanks for the help
				Posted: Sat Sep 21, 2013 3:46 pm
				by pavlo
				Get  sync log
pull plugs
Unplug injectors (unless you want a fire)
Use timing light to check base timing on cranking, if using an adjustable light make sure it's set to zero.
Base timing may need adjusting or you are using the wrong edge direction for the sensor.
I wrote a detailed description of using the manual cam checklist which also includes info on determining phase. But essentially if it goes 720 in the wrong phase it will simply not run, so if it kicks back it suggests the timing is way out.
				Posted: Mon Sep 23, 2013 7:53 pm
				by wrxbart
				Where is the detailed description you wrote mate ?
				Posted: Tue Sep 24, 2013 1:41 am
				by pavlo
				Posted: Tue Sep 24, 2013 10:12 pm
				by wrxbart
