Page 1 of 2
A/C input
Posted: Sun Sep 08, 2013 3:01 pm
by TimH
My Subaru S6 PnP, by default, takes the air con control in. I've had a quick look through SCal and can only see it used to increase idle rpm. Is it used for anything else that I've missed?
If not, I may well re-use the input for other things.
Re: A/C input
Posted: Sun Sep 08, 2013 8:27 pm
by pavlo
increase idle, increase base duty, and turn on the A/C compressor output after it's raised the idle.
However, you will need to bridge the pressure switch if you want to use the actual A/C switch as a useful input.
Re: A/C input
Posted: Sun Sep 08, 2013 9:18 pm
by TimH
Thanks Paul. My Cal has no "adders" set for A/C, but fair point about the A/C output control as I missed the obvious (no change there then lol).
I can see that the A/C output has off/on engine speeds and throttle positions, which makes sense as I know my A/C turns off when driving hard...so will ponder whether to simply drive the pressure switch via a relay and decide myself when to turn the A/C off or maybe just use an engine-speed output function to "gate" the relay to give some degree of automation.
Re: A/C input
Posted: Mon Sep 09, 2013 12:20 am
by pavlo
What are you trying to do? The nitrous strategy can do a lot.
Re: A/C input
Posted: Mon Sep 09, 2013 12:25 am
by TimH
Just free up an input - only one that seems a good candidate is the A/C input.
Taken a quick look at the NO stuff and can see that has all the control I should need....just a question of whether A/C control really needs to be smart or if simple on/off will suffice?
Re: A/C input
Posted: Mon Sep 09, 2013 12:30 am
by pavlo
SO you don't have a spare ignition output that you can hook up to a regular ignition amp to turn it into a high level output?
Re: A/C input
Posted: Mon Sep 09, 2013 12:34 am
by pavlo
Sorry you said input!
Re: A/C input
Posted: Mon Sep 09, 2013 11:37 am
by TimH
Lol, yes Paul, trying to free up an input :)
Is it worth trying to semi-automate the A/C control using the NOS strategy, in your opinion, or shall I just bridge the input to the AC pressure switch and be done with it?
Re: A/C input
Posted: Mon Sep 09, 2013 12:03 pm
by pavlo
You could grind off a tooth from your cams and use your AVCS sensors to get 720 sync like a hawkeye, although the earlier sensors don't put much voltage out at cranking speed, although you could also change the sensor if you're keen.
Have you ditched your cal input yet? ;)
Re: A/C input
Posted: Mon Sep 09, 2013 12:06 pm
by TimH
grinding teeth of cams is a bit excessive for A/C lol.
Perhaps you've muddled replies to 2 different threads :)
If the CAL input question is aimed at me then no, not yet. I have implemented CAL up/down, but the S6 complains about the other missing M4 packets and I am awaiting guidance from Syvecs/LR on how best to deal with this without (further?) upsetting the vehicle and/or S* ;)
