Ignition breakup help needed.
Posted: Sat Sep 07, 2013 6:06 pm
Hi,
This week i tuned the car on our dyno and just to check everything and get to use the S8 i filled her with normal 92oct Gasoline, 10psi and 9000rpm and engine worked perfectely.
Infact I am very happy with the Syvecs S8, its power and safety when you have the boost/knock/limps maps etc all working you start appreciating what a controller this is, and also thanks alot to Ryan and Paul
for all the help they gave me.
Then today I switched the fuel to 100% Ethanol and on the dyno severe ignition breakup started when applying some load like 0-5psi, idles perfectely, only on load the issue
comes up. Tried different fuel/ignition settings but no better.
I tried different spark plugs, iridium, normal, different heat ranges, different gaps upto 0.5mm but did not make a difference also.
I went back to 100% gasoline and worked perfectely, so it seems that for sure the Ethanol needs more energy to fire and not sure whats going on here.
I am using the M&W Pro14 CDI and AEM CDI Coils.
I have bought this ignition setup for alot more boost than this so why could this happen?
Any help would be appreciated.
Thanks.
Thanks.
