You are asking the wrong questions.
The "CTL" denomination refers to the control board, and should generally be ignored, the only place it really appears is on the I/O configuration in the software and the relationship between CTL pin and OEM pin is different for every ECU or loom adaptor.
All the info you need is here:
viewtopic.php?f=6&t=137
I've copied below, you may also want to get the OEM ECU pinout in PDF to go with it.
A:
09 08 07 06 05 04 03 [] 02 01
21 20 19 18 17 16 15 14 13 12 11 10
31 30 29 [] 28 27 [] 26 25 24 23 22
B:
09 08 07 [] 06 05 04 03 02 01
28 27 26 25 24 23 [] 22 21 20
C:
16 15 14 13 12 11 10 09 08
24 23 22 [] 21 20 19 18 17
D:
07 06[]05 04 03 02 01
22 21 20 19 18 [] 17 16
E:
06 05 04 03 02 01
12 11 10 09 08 07
17 16 [] 15 14 13
AN01 = AB1 Crank (B2)
AN02 = AB2 Cam (B1)
AN03 = AB3 AVCS L (E9)
AN04 = AB4 AVCS R (E2)
AN05 = AU1 Vehicle Speed (D1)
AN06 = AU2 MAF Signal (E13)
AN07 = AU3 TGV L (B13)
AN08 = AU4 TGV R (B23)
AN09 = AV1 Throttle (B7)
AN10 = AV2 MAP (B8)
AN11 = AV3 O2 Signal (B17)
AN12 = AV4 A/C Request (D6 on EU or D5 on JDM)
AN13 = AR1 Coolant Temp (B18)
AN14 = AR2 Air Temp (B27)
AN15 = AR3 Test Mode (D5 on EU or D14 on JDM) [KILL/ALS/LAUNCH/CAL]
AN16 AR4 Neutral Switch (D8) [ALS/LAUNCH/PIT]
A 2001 sti pinout is essentially the same through to 2005.
